Deus Ex Mankind Divided Bench Thread.
21 Sep 2018
The Stratosphere
RTX 2080 @ 2070/8300
i7-8086K @ 5.2GHz
DX11
Driver 411.63
1920x1080
10 Oct 2012
Denmark
4790k@ 4,7ghz
1080 ti @ 1925 core , 5508 mem
dx11 windows 10
Driver: 399.32
1080p
Cant push my 1080ti any faster on the current POS cooling its on atm(paper thin almost meant for the 1070,1080) so i think this is it for me for now..
18 Feb 2015
Highest I can go with my monitor is 2160p.
If I could run 8k I would get something like 25fps using the bench thread settings.:eek:
How about 4K with 4x or 8x msaa? Can't run it on my v64 at all even with hbcc. Really curious to see how much vram it requests on your Titan rtx.
Man of Honour
OP
21 May 2012
Dalek flagship
Thank you very much sir!
Had to use DX11 as the PC I was using won't run the game in DX12 ever since I crashed it overclocking some RX480s on the game, I will need to format the SSD to fix that.
DX11
Maxed out
2160p
MSAAx8
RTX Titan stock
I will do a run in DX12 on another PC with my Titan V but it won't be for some time as the system is behind loads of furniture at the moment while I am decorating.
IIRC on NVidia cards there is not much difference between DX11 and DX12 memory usage in this game and it will run maxed out using either on any of their 11gb or 12gb cards.
Only problem is the fps which for the stock RTX Titan was 12.3fps average.:eek:
