Make sure you've got your angle of attack locked in at this stage or you'll be doing it all over again. If you've got the patience to do that as well you'll make a ton of progress on speed and accuracy. As you get more confident don't forget to practice skipping strings. That's something you can sort out at this time. You are probably better just increasing the metronome by 1 per day and focusing on all that kind of stuff. May not sound a lot at the start but in 2 months that extra 1 will hurt!
Of course! And the bass, piling in under it. Lights my candle anyway (might be because I have headphones on, the recording setup's not ideal).
