Hello guys! so i've had my 9900k for over a month now and decided to undervolt. At stock settings with MCE off, the vcore under load is anywhere between 1.25-1.35v with occassional spikes up to 1.37. I did some digging and from what i understand, this is still completely fine and within specs, my temps are under control, too. However, i dont think this much voltage is necessary for 4,7ghz all core load, so i decided to undervolt. I have been playing with static vcore a couple weeks ago and was getting whea errors running aida64 up until i set the static vcore in bios to 1.190 so im thinking its safe to assume that my 9900k will need roughly 1.2V to do stock settings?
I dont want a static vcore though, so i did some more digging and found about a DVID option on my motherboard (Gigabyte z390 Aorus Master) and from what i understand, this setting should limit the maxium allowed vcore voltage supplied by the mobo while staying dynamic.
if i put a value of -0.150V in the DVID, that would mean the vcore limit would then be around 1.22v considering it creeps up to as high as 1.37 on auto vcore, right?
is this way of undervolting safe for long term use? i dont plan on overclocking right now, the processors performance is more than enough for me.
bios settings :
MCE : off
XMP 1 : ddr4 @2666 cl13 1.35v (creeps up to about 1.38 occassionaly which is fine i suppose)
Turbo Boost : enabled running at stock settings
Hyperthreading : enabled
Vcore : normal
DVID : -0.150v
bios settings :
MCE : off
Vcore : normal
DVID : -0.150v
Wish you all the best and good luck!
