arcade owners, workers or anyone who works with redemtion tickets
11 Sep 2011
hopefully you guys will be able to help. At our arcade we use the paper redemption tickets but we are now after some foam or sponge ones in the same style for one of our machines. We have looked online for hours today and cant find anything of this description but we know they exist as and old arcade in the area used them a while ago but has since closed down.
so does anybody know where we can get custom printed foam or sponge tickets? if you use them at your arcade where do you get them from? any help or links are great.
do you mean a foam version of the roll of tickets?
https://www.imagineersltd.co.uk/sponges/
i do indeed, I have litrally just emailed those guys before seeing this after thinking "hmm maybe i should just search custom printing instead" so hopefully they come through although the sizes im after are minute compared to some of thier suggested products. but fingeres crossed
You could try your luck with sega, udc, or e-service. Suzo is probably worth a shout as well. out of curiosity is this for playfield use or a dispenser?
We cant deal with sega as we are namco but namco dont do what we need:( its for a small e-claw that grabs hand fulls of tickets, but right now its taking up too much time every shift to ball up the correct amount. so with these we can just have a value on that can be redeemed at the desk and dropped back into the machine
I suggest a drawing.
Looks like you can pretty much use anything that has a printed number on it if it's IN the claw machine?
yeah it will be in the machine however the manager is VERY particular with what he wants, has to be a replica of the tickets we use, just slightly larger and printed on the foam. no substitue will do lol. we spent hours today showing him stuff and offering other ideas but it was no no no lol
