ryzen build and no upload speed via wired connection
28 Aug 2017
United Kingdom
as the title i've noticed in the last few days my internet has been acting up and just now i have run tests on my connection on my ryzen 3900x build, my download is 49mb's but my upload is 0mb's via a wire, whats odd is that i have my nephew saying over and he's got a intel build and on wifi and he can hit 48mb's down and 10mb's upload, just wondering if anyone else has this problem and is anyone aware of a fix?
cheers
Wookie87
Bad cable?
Dodgy router?
Does your nephew have the same issue if wired?
cable is around 4 months old and router is fairly new got a new one as updated contract for fiber, havent tested his pc with wire yet, odd thing is my pc was running fine for the whole time i had the cable, in the middle of installing updated chipset and ethernet drives to see if it fixes it
right update, just plugged into the 5gb nic and hey presto my upolad is back and i have a green light and orange activity light, when i plug into the intel 1gb nic i get a red light and very little orange activity light, have i broke the 1gb port or software related?, trying to install the 1gb drives and the asus setup wont lanuch
What motherboard?
Checked device manager - look for yellow exclamation mark next to the network section. Possibly just a driver issue needing sorted.
What motherboard?
its a asus crosshair formula VIII x570 in device manager the intel 1gb shows up and no errors with it, try uninstalling it?
Aye. Uninstall it or check for driver update. Dual lan ports could be causing a conflict (especially if the non Intel one has proprietary software running in windows) dual lan on my x370 went haywire when I installed the windows software for the Killer Nic - from memory it was a similar issue. Made the Intel lan port run like turd.
be back shortly got to uninstall everything network related start again
right i'm back and feel such a tool, turns out i was using my 5gb port all along which is why my internet wasnt working, the drivers are installed for both ports but upload dosent work on the 5gb connection, no idea why, took my pc downstairs the other day for a long overdue clean and plugged everything back in, looks like i used the wrong port for ethernet cable DOH! sorry for the mix up but i appreciate the help
again sorry!! thats my blonde moment for the day :)
I didn't realise that there was a wrong Ethernet port.
