- 14 Apr 2014
- Hampshire
Hi all,
My younger brother is using a gigabyte 780 Ghz Edition with the windforce cooler (triple fan).
He's been complaining lately that the PC has been crashing under load, and recently wouldn't turn on at all.
I tested it on furmark, and fans quickly spooled up to 70% and about 92 degrees under load, drops to about 1040 Mhz on the core - this seems excessive to me. It's a pretty well ventilated case, with 2 intakes and 1 exhaust at reasonable speed.
The PSU is a 650W EVGA GQ. Not the best PSU I know, but should more more than suitable for this GPU.
When I turned on the PC recently, the first time since he said it wouldn't turn on at all, I was greeted with a BIOS message saying that the overclock settings weren't working, so I reset it.
It's running an i5 4460 too, so it shouldn't be overclockable. My initial thought is RAM - it's running XMP.
To summarise:
Any thoughts would be greatly appreciated
To summarise:
- GTX 780 Ghz Edition (Gigabyte) hitting 92 degrees in furmark after 30 seconds, fans about 70%, core about 1040 Mhz. System then proceeds to lockup and reboot required.
- i5 4460, 8GB DDR3 @ 1600Mhz.
