how hard ? looks as though it's easy to clean though, and not attached to vessel ?
we use a Brita atm exclusively for tea/coffee to stop the hardness/scum
I tested our water using a hard water kit and it was about 280 - 300 mg/L.
They're blooming expensive to run as well. Colleague at work has one, praises it to high heaven but then moans at other times about high utility bills.
My old job in Wimbledon had a quooker tap in its office with around 60 people. It was used a lot obviously for tea rounds and otherwise.
It started dripping and needed fixing or servicing every couple of months.
if you have a fast 3kw kettle usually about 3 minutes to boil 1l of water - so thats 1/20th of an hour or 0.05*3=0.15Kw/hrs ~ 2p at 15p/unit
which should be similar to a boiling tap.
for tea/coffee making, I reflected that usually they say you should use freshly boiled water too.
I've got our Quooker tap plugged into a TP-Link smart plug with energy monitoring, and I've got a script which logs a bunch of metrics which has been tootling along for a couple of years.
This is what our power usage looks like for the past week:
On average the tap uses between 0.5 to 1 kWh per day, so between 7p and 14p ish.
Pretty cool! also useful to see that it looks like it would hit about 0.3kwh per day if not used at all. I guess the spikes are from the water being used/topped up and then heated up.
Even at 1kwh per day it would be 14p per day, and that would be a cost compared to boiling a kettle.
Is yours boiling water only, or is it the combi version for hot water also?
We've got the boiling water version. They didn't have the fancy-dan versions back when we got itHaving said that, we have an unvented hot water cylinder that is already storing hot water, so I'm not sure we'd see any benefit to having a separate hot water feed from the Quooker tank.
Gas boiler will always be more efficient compared to electric, I think the combi thing sounds appealing if you can't get a good hot water feed in from anywhere nearby.
How much maintenance does yours require by the way? do you need to replace filters etc?
It doesn't require much maintenance to be fair. Every year I clean and descale the tank and then every other year I also replace the HiTAC filter. It's a bit of a faff to open it up and descale it. It probably takes about 2 hours or so in total, so not the end of the world every year. i also pop the tap head attachment in some descaling solution to clean off any excess limescale.
The past couple of years has resulted in quite a lot of scale build up each time (as you can see from the photos I posted), so this time round I've decided to put a polyphospate filter (https://www.screwfix.com/p/bwt-poly...ge/88345#product_additional_details_container) in-between the cold water supply and the Quooker tap to reduce / eliminate the scale.
although these stop fur in the Quookerso this time round I've decided to put a polyphospate filter
I'd prefer something that replaces the need for a britta water softener we use for tea&coffee to avoid scum (ie ion exchange. / salt rejuvination)These devices leak polyphosphate (a food-grade chemical) into the water. Any metallic heating element immediately after the device becomes coated in a protective layer of polyphosphate. This prevents limescale from sticking to it when the water is heated.
Good point - if it's not sticking to your tank, it's going into your brew!I'd prefer something that replaces the need for a britta water softener we use for tea&coffee to avoid scum (ie ion exchange. / salt rejuvination
