KFA2 ARE SMASHING UP DA DEALS: 2070 SUPER UK's CRAZY LOW PRICE & 10TH ANNIVERSARY IN STOCK!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
KFA2 GeForce RTX 2070 SUPER EX 1CLICK-OC 8192MB GDDR6 PCI-Express Graphics Card @ £458.99 inc VAT https://www.overclockers.co.uk/KFA2...DDR6-PCI-Express-Graphics-Card-GX-0A5-KF.html
27ISL6MDW0BK, Boost Clock: 1815MHz, Memory: 8192MB 14000MHz GDDR6, Cuda Cores: 2560, VR Ready, PhysX/CUDA Enabled, NVIDIA Turing, 12nm Process, Real-Time Ray Tracing, 2 Years Warranty
Only £458.99 inc VAT.
ORDER NOW
KFA2 GeForce RTX 2070 SUPER EX Gamer OC Triple Fan 8192MB GDDR6 PCI-Express Graphics Card @ £469.99 inc VAT https://www.overclockers.co.uk/KFA2...DDR6-PCI-Express-Graphics-Card-GX-0A9-KF.html
Only £469.99 inc VAT.
ORDER NOW
KFA2 GeForce RTX 2080 SUPER EX 1CLICK-OC 8192MB GDDR6 PCI-Express Graphics Card @ £679.99 inc VAT https://www.overclockers.co.uk/KFA2...DDR6-PCI-Express-Graphics-Card-GX-0A7-KF.html
Boost Clock: 1845MHz, Memory: 8192MB 15500MHz GDDR6, Cuda Cores: 3072, SLI Ready, VR Ready, PhysX/CUDA Enabled, NVIDIA Turing, 12nm Process, Real-Time Ray Tracing, 2 Years Warranty
Only £679.99 inc VAT.
ORDER NOW
KFA2 GeForce RTX 2060 SUPER EX 1CLICK-OC 8192MB GDDR6 PCI-Express Graphics Card @ £379.99 inc VAT https://www.overclockers.co.uk/KFA2...DDR6-PCI-Express-Graphics-Card-GX-0A6-KF.html
26ISL6MPX2EK, Boost Clock: 1695MHz, Memory: 8192MB 14000MHz GDDR6, Cuda Cores: 2176, VR Ready, PhysX/CUDA Enabled, NVIDIA Turing, 12nm Process, Real-Time Ray Tracing, 2 Years Warranty
Only £379.99 inc VAT.
ORDER NOW
KFA2 GeForce RTX 2080 Ti HOF 11264MB GDDR6 PCI-Express Graphics Card @ £1,399.99 inc VAT https://www.overclockers.co.uk/KFA2...DDR6-PCI-Express-Graphics-Card-GX-09V-KF.html
28IULBUCV6DK, Boost Clock: 1635MHz, Memory 11264MB 14000MHz GDDR6, Cuda Cores: 4352, VR Ready, PhysX/CUDA Enabled, NVIDIA Turing, 12nm Process, NV Link, Real-Time Ray Tracing, 2yr Warranty.
Only £1,399.99 inc VAT.
ORDER NOW
KFA2 GeForce RTX 2080 Ti HOF 10th Anniversary Edition 11264MB GDDR6 PCI-Express Graphics Card @ £1,799.99 inc VAT https://www.overclockers.co.uk/KFA2...DDR6-PCI-Express-Graphics-Card-GX-0A8-KF.html
28IULBUC38TK, Boost Clock: 1740MHz, Memory 11264MB 14000MHz GDDR6, Cuda Cores: 4352, VR Ready, PhysX/CUDA Enabled, NVIDIA Turing, 12nm Process, NV Link, Real-Time Ray Tracing, Hybrid, 2yr Warranty.
Only £1,799.99 inc VAT.
ORDER NOW
Nvidia RTX! The Rules Have Changed! Promotion - Call of Duty: Modern Warfare @ £49.99 inc VAT https://www.overclockers.co.uk/
Only £49.99 inc VAT - INCLUDED WITH ALL ABOVE!!!
ORDER NOW
3 May 2014
What are the differences between the two KFA 2070 supers apart from one being dual fan, the other being a triple fan and some RBG? :)
Caporegime
8 Nov 2008
Some of my favourite looking cards are the KFA2 ones. Not always the most aesthetically intricate-looking but I kind of like the understated look most of the time.
3 May 2014
Nothing, but the triple fan should give better cooling, so you can probably push the card more.
Well, it certainly looks like the dual fan is thicker and using 100mm fans instead of whatever the triple one is but thought i would ask the question anyway! :)
23 Dec 2018
Very tempted by that 2070 Super dual fan, but I think OCUK have the wrong dimensions for it. The KFA site has it being smaller including bracket, which is vital for me as I think the 29.5cm one will just fit in my case but the triple fan 30.5 cm one likely won't.
The specs here show it as 29.5cm with bracket, not 30.5.
http://www.kfa2.com/kfa2/graphics-card/20-series/kfa2-geforce-rtx-2070-super-ex-1click.html
With that free game it's a great deal, but wish it was more than 2 year warranty. For ones that fit my case there's a Zotac at £488 for 5 year warranty but it's supposed to have coil whine. An MSI ventus for £500 that is supposed to be hot and noisy, then an EVGA black at £530, but both with 3 year warranty.
£458 very tempting.
26 Sep 2019
Hi. First post here.
This is very tempting. I would buy the game anyway so I guess I’m getting the card for £409.
Was thinking of getting a 5700xt for this price.
Hard to find any reviews on this card
I had a 570 gtx from this company and that was a great card
Caporegime
17 Jul 2010
Hmm I’ve been waiting for a 2070S to come into stock at a global PC retailer as I have £480 in vouchers to be spent there. Wonder how much I’d get for them. Something to ponder.
16 Jan 2010
Earth
Two year warranty no thanks. My FE 1080ti has twice failed and would have been out of warranty the second time with a pathetic two year warranty. They should all have a minimum three year warranty as GPU failures are not that rare.
31 Dec 2008
It seems graphics cards that run hot are very likely to fail at some point. None of my water cooled cards ever died on me no matter how much abuse they had to take including shunt mods etc. and many of them were second hand.
Now I had two GPUs in laptops die as they were running at around 90c.
So yeah it's most of the time heat that kills graphics cards unless they were faulty out of the box.
That's my experience anyway.
11 Aug 2004
Southampton
I have the same card and its been fantastic easily as quiet as the MSI 2080 Tri Cooler.
I go between both those PCs and you cant tall the difference in sound or FPS.
Very impressed with it.
11 Aug 2004
Southampton
I have had various card all the way from the voodoo series and matrox.
only had a couple of faulty cards and they seemed to have been faulty from the start. I also never overclock my GPUS and all of them touch wood have been working and are still working now.
I just have been lucky in that regard.
