kr00t0n's GPU buyers guide September 2019 (rough)
Caporegime
9 May 2004
Leafy outskirts of London
Having been a laptop gamer for the past 4 years, I have been a bit out of the loop in terms of GPUs.
I started paying attention again due to Cyberpunk 2077 coming out next year, and looking at where I can get good bang-for-buck.
This is a very rough guide, based on quick eyeballing of current average pricing (both new and second hand). Thought it might be helpful.
Based on this GPU hierachy (which I am sure most of you spit at :D).
I will sort by best £ per performance looking at new Nvidia, new AMD, and a second hand card options.
£150 range
Second hand 1060 6GB (£130ish) : £2.5 per performance point (53 points)
New 580 (£160ish) : £2.8 per performance point (58 points)
New 1650 (£160ish) : £3.8 per performance point (42 points)
£200 range
Second hand 1070 (£200ish) : £2.9 per point (70 points)
New 590 (£200ish) : £3.3 per point (61 points)
New 1660 (£220ish) : £3.4 per point (64 points)
£275 range
Second hand 1080 (£270ish) : £3.2 per point (84 points)
New 5700 (£300ish) : £3.4 per point (88 points)
New Vega 56 (£280ish) : £3.6 per point (77 points)
New 1660Ti (£270ish) : £3.8 per point (71 points)
£350 range
New 5700XT (£375ish) : £3.9 per point (96 points)
New 2060 (£340ish) : £4.4 per point (78 points)
New Vega 64 (£380ish) : £4.5 per point (84 points)
£425 range
Second hand 1080Ti (£400ish) : £4.2 per point (96 points)
New 2060 Super (£400ish) : £4.7 per point (85 points)
New 2070 Super (£475ish) : £5 per point (94 points)
£500+ club
2080 upwards all scale as expected (ie getting way more expensive per point)
AGAIN THIS IS ROUGH
So Nvidia's 10x range do great in the second hand market on the cheaper side of the scale, but if buying new, AMD offers more bang for buck in the sub-£400 realm.
Hope this is useful to someone trying to figure out their budget options and appetite for second hand.
Moore's Law Is Dead did his own GPU hierarchy because he felt the Tom's Hardware one was utter gash. Would be interesting to see his performance tiers compared to your pricing.
2070S in 425 range.
Unless Gibbo's KFA2 deals are actual fixed price drops then no, it's not.
Even if they're not fixed, then yes, it is that price range.
EDIT, oh I see what you mean
I don't know about a second hand 1080Ti getting so high a rating. Also that rating completely ignores the RTX features of the Turing cards.
And I don't think you should include special deals that only last a few days in your buying Guide. Because that's not their actual price. When the deal is over the price will return to normal.
Not if you are doing a buying guide that might not be finished by the time the offer is finished. He should just put a caveat at the bottom saying that from time to time cards might be on special offer.
£150 range
£200 range
£275 range
£350 range
£425 range
£500+ club
AGAIN THIS IS ROUGH
You could argue that a Vega 56 can be flashed to a Vega 64 in some cases. And that you can make a 5700 perform like a 5700xt using similar methods. Making both cards have a lower price per point
Can't be flashed to a 64, since the hardware won't be unlocked.
Without any offers the 2070S can always be had sub 500.
I haven't looked at lowest price, I've roughly eyeballed the (lower) average price (so ignoring special editions and what-have-you that fetch higher prices) across OCUK and a few other sites.
As I have said, it is all ROUGH :D
Umm I've owned 3 and flashed them to 64 and 64 liquid, is a well known and easy thing to do. The missing shaders make 2% difference, max, in a very small amount of games
Even had a 64 and 56 flashed in crossfire beating 2080ti scores
It stops being an easy reference if you take things like flashing, overclocking, etc. in to account.
This can be a stock/baseline list, and if people want to find out how to min/max cards they can do so themselves. :p
Flashing to a 64/5700xt is different to overclocking but ok
