How Does This Spec Look!
13 Feb 2009
London
Does this spec look ok?
It's for someone who don't game, but wants a fast pc for internet, and there business stuff.
They want to use onboard graphics.
Will all this work ok?
Cheers ;)
AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail £199.99
https://www.overclockers.co.uk/amd-...hz-socket-am4-processor-retail-cp-3ac-am.html
Corsair RM Series RM650 650W '80 Plus Gold' Modular Power Supply £89.99
https://www.overclockers.co.uk/cors...lar-power-supply-cp-9020194-uk-ca-24r-cs.html
MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard £106.99
https://www.overclockers.co.uk/msi-b450-tomahawk-max-socket-am4-ddr4-atx-motherboard-mb-33t-ms.html
be quiet! Pure Base 500 Midi Tower Case - Black £69.95
https://www.overclockers.co.uk/be-quiet-pure-base-500-midi-tower-case-black-ca-13p-bq.html
Alpenfohn Brocken ECO Advanced CPU Cooler - 120 mm
https://www.overclockers.co.uk/alpenfohn-brocken-eco-advanced-cpu-cooler-120-mm-hs-05j-al.html
Corsair Vengeance LPX Black 16GB 3200 MHz AMD Ryzen Tuned DDR4 Memory Kit
https://www.overclockers.co.uk/cors...md-ryzen-tuned-ddr4-memory-kit-my-4bx-cs.html
Samsung 970 EVO Plus Polaris 250GB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive
https://www.overclockers.co.uk/sams...-3.0-x4-nvme-solid-state-drive-hd-23x-sa.html Total £650.89
Terrible.
The 2700x does not have intergrated graphics, and is massivly overkill for "internet, and there business stuff".
A 650w PSU is again overkill for a build with no dedicated GPU.
Motherboard is fine.
Case is fine.
The stock coolers that come with the AMD chips will be ample for your use case.
You can easily get cheaper 3000mhz RAM and you wont see the difference.
The 970 Evo is massivly overpriced you can get double the space for less.
My basket at Overclockers UK:
Total: £526.10 (includes shipping: £13.20)​
If ocuk can confirm an up to date bios you can go cheaper on the board with something like an ASRock B450M Pro 4 for £71. No need to spend over £100 on a board.
No need for an expensive case either as no gpu and a lower end cpu means it will run cool anyway. Something around the £30 mark for a basic case is all you need.
I doubt they need NVMe unless they are moving large files around ? A cheap SATA like the Team Group L5 or WD Blue SSD would do ok.
Like the previous replies.....
- No integrated graphics so get a 2200g or 2400g for more mobo compatibility.
- Any B450 motherboard will be fine and you don't one with the most up to date bios.
-Don't really need cpu cooler, stock is fine.
-PSU wattage is overkill and even a good quality 300w is fine.
-NVMe ssd is great but most people will be fine with sata ssd and right now 500gb is the best value.
Thanks for the advice guys.
How does this look?
Of course i want reliable items.
Is this M-board good enough to overclock the cpu to 4.2 with the stock cooler ?
Cheers Guys.
AMD Ryzen 5 3400G Quad Core 4.2GHz (Socket AM4) APU with RX Vega 11 Graphics - Retail
https://www.overclockers.co.uk/amd-...ith-rx-vega-11-graphics-retail-cp-3ba-am.html
be quiet! Pure Power 11 400W 80 Plus Gold Modular Power Supply
https://www.overclockers.co.uk/be-q...plus-gold-modular-power-supply-ca-130-bq.html
Gigabyte 240GB SSD 2.5" SATA 6Gbps Solid State Drive
https://www.overclockers.co.uk/gigabyte-240gb-ssd-2.5-sata-6gbps-solid-state-drive-hd-004-gi.html
Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey
https://www.overclockers.co.uk/team...al-channel-kit-grey-tlgd416g30-my-087-tg.html
Asrock B450 Pro4 (Socket AM4) DDR4 ATX Motherboard
https://www.overclockers.co.uk/asrock-b450-pro4-socket-am4-ddr4-atx-motherboard-mb-16b-ak.html
Raijintek Arcadia II Midi-Tower Gaming Case - Black Window
https://www.overclockers.co.uk/raij...tower-gaming-case-black-window-ca-03w-rt.html
