- 4 Aug 2007
- Wilds of suffolk
Hi,
A ballpark type question for an electrician really.
We are starting to plan a kitchen refurb and our current Cu is in a cupboard in the kitchen. Its a bit of a pain as it makes a mess of that cupboard.
So ideally we would like to move it. It backs onto an internal wall, that we would ideally like to have the CU on the other side, the utility. Its a breeze block wall, plaster boarded on both sides.
So the question is is it possible and if so what sort of amount of work?
So questions really :
assuming its ok to move, would you just drill a decent hole, 40mm or something as the route to reroute the cables?
Assuming its possible, and assuming the cables are too short to just rewire into the box is it possible/reasonable to extend the rings to go through the wall.
The meter cupboard is on the outside wall, pretty much level with the CU, but lower down. So I would assume the meter to Cu cable being about 1.5 meters long could just be replaced.
IIRC we have 3 or 4 (I think 3) lighting rings, and 3 or 4 (I think 3 again) socket rings, plus a cooker circuit, a boiler connection, a fire alarm circuit etc. So assume 12 say.
If I was to get this done would we be looking at half a day, a day, more etc time.
Is it logical to replace the Cu at this time, they don't seem that expensive, so going to a latest gen would seem worth doing at the same time.
