Hi guy, the reason I ask is, I am with sky and when I was using the sky hub, I had nothing but trouble, so I spent £200-£300 buying my own stuff, BILLION router(compatible with sky and fibre), changing the phone master socket and getting some wifi unifi access points.
Since I have changed all the stuff, the net has been flawless. But now I have just found out that bt is upgrading us to fibre as they have been working today at the bottom of my driveway.
So what I want to know is,, If I upgrade the sky from broardband to fibre, will it just be a matter of flicking a switch at their end or will bt have to come into my house to install stuff?... If bt have to install stuff in my house, they change all my equipment for theirs and I am a tad concerned about that... Plus with being in a wheelchair with a stammer, people think I have a screw loose, so I try to say as little as poss.
So have any of you guys upgraded from adsl broadband to fibre and what was the process?
