Bold as brass, no one bats an eyelid. Probs done them a favour with that car however.
Loads of similar videos on Youtube
Watch it again. The clamp only secures the locking mechanism to the pipe. The steel cables (claimed to be almost impossible to cut through) loop around structural chassis elements, so when you've cut off the pipe, the cut section of pipe it still tied to the car.I watched the video: the clamp is fitted on the pipe leading to the cat so they just the pipe behind the clamp. Or they cut the cables with a bolt-cutter.
If you had a van you could make it look legit by putting some bogus garage name and wearing some high vis etc. Not that anyone bats an eyelid anyway.Loads of similar videos on Youtube
In this one, he even has a quick check to make sure no one else has already nicked it. From rolling the jack under the car to dropping it back down again, less than a minute.
Nice little satisfying crunch noise. Imagine if the car just trapped them whilst calling the police they were stuck there with their legs kicking. Thinking about it, you would probably get arrested.If only a person who walked past turned the handle on the trolley Jack and squashed the *******.
Nice little satisfying crunch noise. Imagine if the car just trapped them whilst calling the police they were stuck there with their legs kicking. Thinking about it, you would probably get arrested.![]()
