- 5 Oct 2019
- United Kingdom
Hi,
I recently purchased a
EK-VECTOR RTX RE RGB GRAPHICS CARD WATER BLOCK - NICKEL + PLEXI from Overclockers, to compliment the CPU cooler I installed last week.
I have a Gigabyte GeForce RTX 2080 Gaming OC 8G, 8GB GDDR6 (GV-N2080GAMING OC-8GC) which according to the page for the water block, is compatible. (though EKWB's site says they don't make a compatible cooler for this card)
I have it on a dedicated loop, with it's own pump, 120mm radiator and reservoir.
With the stock fans for the GPU while playing Overwatch I would run at 38 degrees C, with the new EK-VECTOR all my games are running around 85-88 degrees C, with no other changes made to the system.
Water is flowing smoothly, micro bubbles occur, and when not gaming the GPU drops down to 36 degrees C pretty quickly.
Any thoughts/ideas folks?
