- 11 Sep 2013
NVM
Xfire 290 and 2500k 30-40 under load on a warm day but my temps have gone up to 50 on a hot day. One gpu and my temps never go above 40. I have set my fan speeds to keep 5’c delta which this summer was 7’c delta and high 30’c gaming, this is a dirty system I need to clean out the dust in the rads and I’m 2 years over due a coolent change.I've finally got my first custom loop up and running and I dont actually know what an acceptable temperature is for the water.
Cooling my system (see sig) is an EK D5 PWM pump, Black Ice 360 GTS, Black Ice 360 GTR (I think, its the 60mm thick multi port one) with Corsair ML120's on both rads.
I've left Heaven running for about 15 minutes now and the temps are as follows;
Water: Fluctuating between 36-39c
GPU: Around 40C
CPU: Around 44-50c (which i dont understand since its only at about 10% load).
The above temps are achieved with all 6 fans at 1000rpm and the pump at 3600rpm.
I'm a bit concerned that when i start gaming and the CPU comes under the load the above temps are going up pretty sharply.
Thanks
No idea what "supercruise" is?
Be carful with them demciflex I had a 240 after a while it started to sag and foul the fans. Apart from that they are good filters but expensiveMade one small tweak and removed the dust filters (DEMCiflex ones that i paid a fortune for) and water temp is now at around 38c with the fans at 1000rpm. I guess DEMCiflex filters aren't all they're made out to be.
I can’t see how that would make any difference to performance. Coolent flows from one port, though half of the rad to the end where it goes though the other half of the rad in a U shape.
I get it’s not a normal side to side U flow, it’s front to back U@red eye These aren't normal rads though. The Hardware Labs rads have a optimum setup due to them being dual pass radiators but not in the normal way. My GTX's for example have a pair of cores layered one on top of the other. The water comes in through port A travels down the rad through the top core then switches to the back core and comes back up the rad to exit at port B, in effect cooling the water twice. There is a picture and explanation of it in this review.
