Hi, I have this very strange problem with my new X570 ACE, Ryzen 9 3900X and Crucial Ballistix 32GB (4*8GB) CL16 3600MHz Micron E-Die memory kit which is on the QVL. If I try to adjust the DRAM voltage nothing happens and it remains at 1.232V according to the BIOS and HWInfo, this means it will fail to POST above 3200MHz because the RAM kit is not getting the required voltage. I have tried clearing the CMOS and flashing an older BIOS but the problem persists. I suspect a hardware fault on the motherboard but would be interested to know what you think.
