- 11 May 2007
- Surrey
Do you have any links to what you mean??
Sure. The OBD port is used for diagnostics, but you can buy your own and pay as little as £5 to God knows what. I think I paid £7 for one and it packed up after a year. All the OBD reader does is get plugged into your car, and feed data to the apps.
First app I use is: https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en_GB which is great for diagnostics and live data. It can even keep a log of readings and speed etc so you can pinpoint exactly where you were seeing problems (ie throttle position full on, and no change in acceleration).
The second is the VAG DPF app, which will, if your car is supported, give you information about the state of the DPF: https://play.google.com/store/apps/details?id=com.applagapp.vagdpf&hl=en_GB
It's worth noting that DPFs are a complete PITA, what's happened to you happened to my Bother in laws C-MAX, and he ended up doing what another poster did, flogging it to WBAC when it was warm and the error messages were clear.
