 - 9 Oct 2019
Hi all, so i have recently purchased a 'Seasonic SSR-750PD2 Prime Ultra 750 W Platinum' PSU - it's a modular power supply that comes with (amongst others) 2 x 4 SATA power cables that connect to 2 of the 4 modular ports on the power supply that are marked as 'Peripheral-IDE/SATA/Molex'.
My question is, am i safe to plug in an additional 2 x 4 SATA power cables to the other 2 unused ports marked as 'Peripheral-IDE/SATA/Molex' ?, and if so does anybody know where i can purchased cables compatible with my PSU, ideally directly from Seasonic.
I am fully aware of SATA power splitters, but i would ideally not want to use them if i can get away with it (additional risk of splitter becoming disconnected).
See image below for the modular ports available on the PSU:-
https://images.app.goo.gl/TrKL8VCRhjn8Dw8q7
Many thanks for any replies.
. im not clear how i could get 20 drives connected, as there are only 4 available ports marked for sata/molex use on my particular psu, and as each port has 4 connectors i think my max is 16, right?.
 your one has 4 like you said so 16 is fine.
