Thin 360 vs thick 280?
22 May 2010
Minibotpc
which would benefit the most in performance? Those are my options as my current one at the front is a standard 30mm thick 240 rad.
Wanting to upgrade to a larger one but my options are a thick 280mm or a slim 360mm
Which is better?
Thick 280 would be my choice and will most likely outperform the thin 360 while making less noise. I have just swapped from a pair of thick (60mm & 65mm) 360 radiators to a pair of Black Ice Nemesis GTX280 54mm thick radiators and my temps have actually dropped a degree or two while having four fewer fans (both setups run push/pull) and running them slower.
There is not that much difference in surface area between a 360mm and a 280mm which is one of the reasons I dropped to a pair of 280mm rads. FPI, fan speed and the flow path inside the rad can make a big difference as well.
280 rad = 39200 mm2
360 rad = 43200 mm2
280 can be used in more cases, takes up less space and allows fitting heights to therefore be adjusted somewhat. A 360 usually only fits one way forcing the fittings to be in a specific place and many cases won't accept a 360.
Going from a pair of thick Coolgate 360mm rads (CG360 & G2 360) to a pair of thick Black Ice Nemesis GTX280 rads my temps have actually gone down as well as the fans making less noise. The new rads are better than the old rads but I was very surprised at the outcome. I am sitting here now with the water temps at 10.8 degrees C and dropping still (rads mounted in a box on a windowsill sucking outside air through them) with the fans (8x Arctic Cooling P14) running at 6v, 800rpm.
that's because the GTX is a much better rad.
What sort of temp differences would this give?
really hard to say. the aim is to have more cooling than necessary in which case it would make no difference. If the 360mm rad was barely coping, a 280mm in its place would result in increased temps.
Trying to make the same decision myself as my Meshify C can fit a 360mm if a bit awkwardly.
Also are 140mm fans not really water cooling optimized like a large amount of 120mm's are?
there are plenty of 140mm water-cooling optimised fans equivalent to the 120mm ones. e.g. ML140 are simply bigger ML120.
Lower FPI and thick rad you can’t go wrong in my opinion, which is why the HWLabs makes a big difference.
They aren't lower FPI though. My GTX's are 16FPI, most other thick rads are in the 7-10FPI range. I know the HWLabs rads are probably the best around which is why I went for them but lower FPI does not always get the best results.
