 - 26 Jul 2010
 - Wiltshire
Just a thread to discuss what hourly rate dealers are charging for service and repair these days, it is a long time from my £49.50 + VAT memories of the mid 1990s !
			Pretty sure is down to the complexity and skills to plug a cable and replace whatever part the computer tells them. When the greasy monkey walks around, sorry, I meant the engineer, and is adamant that any issue where the customer can't be charged for it, is characteristic of the car... Too bad it's simpler to keep the warranty using them.I find that BMW / Mini are just about the most ludicrous I’ve come across for not only the cost, but the ridiculous amount of time they want to do the smallest job.
For example, replacement EGR valve on my sister’s Mini Cooper D they wanted to charge for 3 hours labour. I’ve literally just had mine replaced, on my driveway, by Mini Emergency Assistance under warranty - it took the guy less than an hour in heavy rain. That’s on my Mini Clubman SD - so unless it’s that much easier to do on my car I’ve no clue how they can justify it at the dealers.
General procedure is they will charge you for "inspection" of the problem by plugging into OBD and read from the computer, they might not charge you though for the inspection if you let them carry the work if you argue with them over the price they charge.
Labour hour generally go between 50-100+ per hour in the common dealers(no idea how much exotic dealers charge but way too much for obvious reasons), they may inflate the price on parts aswell and then try and explain there is a "slight" discount by them not charging the "inspection".
Also the price vary depending on the car itself, I do recall one of my previous employees trying to get engine oil or brake pads for his R35 GTR from Nissan dealer part department and they inflate the price of oil automatically if you tell them its a R35 GTR.
I bought an X1 in 2012. Owned it for just over 7 years. Only claimable item was probably the exhaust clamp I had replaced last year. At £500 or whatever a year they wanted for the warranty, I was £££ in without it. The car covered below average miles, trading it recently with about 59500miles on itI hedge against it with a service pack and BMW warranty.
I did put + next to the 100 as i'm only rough guessing.50-100 uwot? BMW are 140/h + VAT. Won't find a backstreet shed garage for under 70+VAT here.
I personally would absolutely not want Halfords changing my transmission fluid
To be honest that receipt seems less than useless in terms of service history, you might as well have done it yourself for half that again if you didnt care to maintain it. I'd actually say that a main agent headed parts receipt would actually look much better than a Halfords one.
You got Halfords to service a 17 plate A6?
I guess this depends entirely on the way that you own the vehicle, do leases merely require any VAT registered garage to follow the schedule?Yeah to be honest the service is good and competitive. They even collect and deliver the car back to us F.O.C.
They update service history digitally and stamp the book for us.
We used to get them done by a guy in a white van.
