Well how many people knew about the update (was not a new GPU Bios more like Interls Management Engine Firmware update but for the DP) to fix the black screen on DisplayPort, not many by my reading here before joining.
It is beyond the scope of many people who buy PC's or a new GPU can fit it and install driver but but do not know about these more technical things.
In case anyone has not done so already (had to update my 1080Ti but Titan Xp was already up to date).
"NVIDIA "Maxwell" and "Pascal" graphics architectures introduced support for modern display connectivity to keep up with the breakneck pace at which display resolutions are scaling up. The two introduce support for DisplayPort 1.4 and 1.3, however the implementation is less than perfect. Some of the newer monitors that leverage DisplayPort 1.4 or 1.3 standards don't function as designed on "Maxwell" (GeForce GTX 900 series) and "Pascal" (GeForce 10-series) graphics cards, with users reporting a range of bugs from blank screens until the operating system loads, to frozen boot sequences.
Unfortunately, these issues cannot be fixed by driver updates, and require graphics card BIOS updates. Luckily, you won't be at the mercy of lethargic AIC partners looking to limit their warranty claims by going slow on BIOS updates, or NVFlash rocket-science. NVIDIA released a tool which can detect if your graphics card needs the update, and then updates the BIOS for you, from within Windows. The app first unloads your driver, and flashes your graphics card BIOS (a process which must not be interrupted, lest you end up with an expensive brick)."
https://www.nvidia.com/content/Driv...ter_1.0-x64.exe&firmware=1&lang=us&type=Other
