Is this small enough?
Yes, that is a good size, if no performance hit. Not sure why, just one day, Istarted wanting to beable to make the smallest case, that will accept a normal size gpu & a psu.Is this small enough?
There pretty small when you consider what your getting is a powerful self contained computer - Motherboard/PCB, Processor/GPU and Ram/VramI wonder if a desktop GPU could be the same size as a Laptop GPU & specs be the same? A APU is it tied is with a cpu, so seems not so hard.
APUs and laptop GPUs are lower performance so need less power regulation circuitry, APUs use system RAM and the SOC VRM so you can pack them onto the CPU package.
Performance is still limited though.
That's just a GPU though, not an APU.
MXM modules, about as small as it can be done just add the output connectors and power connector.
