Hi.
I previous had a i7-7700k & 1080ti and decided to do an upgrade.
The only thing that is the same on this build is the 650w Gold 80 PSU (Corsair), the fans (RGB LL fans 8 in total) and 250GB WD Blue NVME.
2. I have tried rebooting the PC, and I thought at first that would fix it first time round - but it doesn't it takes anywhere between 10 - 15 minutes to get stable and useable.
3. The first time I noticed this was on first boot on the WD Blue (With my old OS). I thought it may just be the OS so I wiped and clean reinstall windows 10 pro twice.
4. Furthermore when this "Freezing" is happening and I try and open Geforce Experience, it comes up with a 0x0 error saying it cannot start and to restart the PC. When the "Freezing" has stopped, it opens it fine.
5. FPS wise I am getting 140+ in some areas on GTA5 with all settings maxed and 1440p. Rocket league (Obviously) 144FPS (I have a 144hz monitor). Other games like Ghost Recon Breakpoint I am getting NO lag at all, no artifacts no freezing ONCE the initial "Freezing" at the start of booting the PC stops.
6. I'm not entirely sure what it is, when I installed the 2080ti BEFORE upgrading the motherboard and CPU, none of this lag was happening.
I would appreciate any ideas. The only thing I notice on the motherboard is its a 12 pin (8 pin + 4 Pin) on the motherboard head. My PSU only had a 8 pin cable as the old motherboard only used 8 pin. From what I can see using 8 pin and 4 pin is not needed, its just optional. I may be wrong.
If someone could assist, please let me know!!!!
Thanks
- KFA2 2080ti SG
- i9-9900k @ 5ghz Overclocked
- Asrock Taichi Ultimate
- 1TB Samsung Evo
- OS on 250GB WD Blue
Thanks
