Who does? Which chipset? Which board? Which slot combination?Yes but they cut the GPU slot from x16 to x8.
If you want Intel then you need to adjust your perceptions. You should be wanting the best for your money and research accordingly. If Intel proves to fit your requirements then go Intel. But wanting Intel for Intel's sake (or any company for any company's sake) is preposterous.If you want Intel, go Intel.
No, that's still sounding like researching the best for your needs. And if vendor X meets your needs then go vendor X. But don't just go vendor X because it's vendor XBest for money isn't always the be all end all, it could do with current platform, software, preference over Intel drivers to AMD's etc.
Errr only if you use the second GPU slot. You can go via the chipset.Yes but they cut the GPU slot from x16 to x8.
I was going to say, on my 8086k which I believe has fewer lanes than Ryzen 3xxx CPUs, I have x16 on my 2080 Ti and I have a 10 Gb PCI card in the PC.Errr only if you use the second GPU slot. You can go via the chipset.
By the time that an average home user requires 16 cores (which is a long, long way away), there will be other 16 + core CPUs out that will smash the 3950X into the park. 6-8 is the sweet spot now and will last for quite some time.
That's probably because you're only considering gaming, where the R5 3600 is a better bang-for-buck choice than the R7 3700X. Intel's closest priced chip to the R5 3600 is the i5-9400, which is much slower and doesn't even have SMT. The nearest real competitor is the i5-9600K, which is ~25% more expensive and requires overclocking to beat the R5 3600 in per-core performance (and still doesn't have SMT).
My comparisons were clearly based on cost. The i7-8700K costs 50% more than the i5-9600K, which is 25% more than the R5 3600.I would put the 3600 more in line with the 8700K than the 9600K.
I mean the 8700K is the same as the 9600K but like the 3600 has SMT.
