Hive radiator valves
Man of Honour
20 Sep 2006
Has anyone used these, if so any feedback on ease of fitting? I have hive in my house and annoyingly the heater 'rooms' are set to living room and rest of the house with both thermostats being downstairs. This means in the colder months my bedroom ends up freezing while downstairs is warm. I know I could move the thermostat upstairs, but I don't want the heating on in all bedrooms as only 2 are occupied.
You don't need digital thermostats to achieve this. Traditional thermostatic values would suffice.
Sounds like you need to turn your downstairs valves down so more heat goes upstairs.
All my radiators are set to the desired temp using mechanical thermostatic valves (bit of trial and error required) heating comes on and all the rooms reach desired temperature.
If one room doesn't heat up a quickly as the others or to my preference, I open the non-thermosatic valve end until it does.
google thermostatic radiator valves and balancing a heating system.
Mechanical thermostatic valves are amazing things.
Inside each one is a wax capsule which pushes a metal rod out (with a lot of force, but only about 1cm max) as it heats up and screwing it up or down regulates how far the capsule has to heat up/push the rod out to close the radiator valve.
It needs a bit of effort to dial in what you want but once done it completely runs off the heat of the radiator.
Electric TRVs try to do the same job with more components, a battery and they have to "learn" how much to open a valve over several days, which I suppose is the equivalent of balancing a regular system.
Sounds like you need to balance your heating system.
I have Hive but not the TRVs. I belong to a Hive Tech support group on Facebook and every other post is an issue with the TRVs.
For that reason I won't be bothering.
Thanks all, I did have a try at balancing the system. I'll have another go once the temperatures start to drop and I need to put the heating on.
Just read your post again, you can also turn off the radiators in the rooms you dont want to heat.
We've had 3 different brands over the years and there's always one (in any of the rooms) that ends up making a high pitched whistle and to stop it you have to be up or down half a notch so the room ends up hotter or colder than you wish and at least 4 occasions the pins have stuck down and had to be belted with a nail tip and hammer to free them again.
So unless there is a particular brand that stands out from the rest that doesn't have these issues they have not been amazing for us. :)
We have standard thermostatic valves in most rooms and they do they job, some rooms don't have them though such as the living room because that's where the temperature control panel is so that regulates it.
Rooms that are not used much are just set low, I don't turn them off fully.
I use the energenie eTRVs with Nest, work a treat - not sure if they will interact with Hive though (IFTTT maybe?). Batteries last 2 years. HTH
All our Tado TRVs work a treat, being able to configure every radiator indivdually, with their own weekday and weekend schedule is ace.
In my case they were all stuck up and wouldn’t go down so the WD40 did it’s job there. Did you have to replace the entire valve or were you able to just replace the washer?
There's loads of vids on youtube with various ideas from tapping the pin down to knocking on the side to try and free the sealing washer so it pops up.
Tapping the pin worked on 2 of our valves and they have never stuck again but 2 others got replaced , not sure if you can replace the washer as the engineer just changed them.
I had the Hive system installed yesterday and did the radiator valves myself afterwards. What a bloody faff. They are right pain to set up and the app crashes constantly when adding them.
One tip I discovered - when the app just hangs and says it can't find the valves - just click back until you are back at the homescreen, then the valve will magically appear.
What should have taken no more than 30 mins to do 6 valves ended up taking about 4 hours with loads of time resetting the damned things and adding them again.
Anyway, they are in now but I'm not sure that they are very useful. I would expect the boiler to fire up if I turn up one of the valves manually but it doesn't.
Electric TRVs presumably have the benefit of being able to set different temperatures at different times of day though (e.g. reducing heating in Kids bedrooms during School hours etc).
Have you looked at this?
Heat on demand
If you also have a Hive thermostat you can enable Heat On Demand in your Hive Radiator Valve’s settings in the Hive app.
Once you have enabled Heat On Demand, your Hive Radiator Valve will boost your thermostat automatically to turn on your heating and make heat available to your radiators when they need it.
When Heat On Demand turns the heating on, every radiator will be provided with heat. Rooms with thermostatic valves (including Hive Radiator Valves) will warm up until they reach their target temperatures. Rooms with manual (on/off) radiator controls will continue to heat up until the boiler switches off again.
If you don’t have a Hive thermostat, or if you disable Heat On Demand, then turning up a Hive Radiator Valve will only warm up the room if your heating is already on.
Heat On Demand works best when you have Hive Radiator Valves on all your radiators. In this setup you will only warm up the room that needs heat. We don’t recommend using Heat On Demand if you have lots of manual radiator valves, as you may end up warming more of your house than you intend to.
https://www.hivehome.com/radiator-valve-guide/using-your-hive-radiator-valve
