- 26 Nov 2014
- Stoke
Available for preorder now, we have the new Kolink Classic and Modular 80+ Bronze 230V EU Power supplies. The Classic and Modular series build on the original KL Bronze units from Kolink, adding improved internal designs including DC-DC conversion and a 120mm fan with fine tuned RPM curve for quiet operation. All the units now come with flat black cables as standard and a new fan grille. In fact the entire design of the PSU is a step up from the previous iteration, even if most of you hide it behind a PSU shroud
The warranty has been increased to 3 years for the entire range, and the wattages range from 400W - 700W wired, and 500W - 700W Modular. Stock will arrive in the next 10-14 days and represents another solid upgrade from Kolink.
Kolink Classic Power 400W 80 Plus Bronze Power Supply @ £36.95 inc VAT
Modern look with flat black cables, 348W and 29A on a 12V rail, 80 PLUS bronze certificate for high efficiency, ATX form factor with a length of 160 mm
Only £36.95 inc VAT.
ORDER NOW
Kolink Classic Power 500W 80 Plus Bronze Power Supply @ £39.95 inc VAT
Modern look with flat black cables, 444W and 37A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £39.95 inc VAT.
ORDER NOW
Kolink Classic Power 600W 80 Plus Bronze Power Supply @ £44.99 inc VAT
Modern look with flat black cables, 546W and 45.5A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £44.99 inc VAT.
ORDER NOW
Kolink Classic Power 700W 80 Plus Bronze Power Supply @ £49.99 inc VAT
Modern look with flat black cables, 648W and 54A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £49.99 inc VAT.
ORDER NOW
Kolink Modular Power 500W 80 Plus Bronze Modular Power Supply @ £44.99 inc VAT
Modern Design, Semi-modular cable management, 80 PLUS bronze certificate for high efficiency, ATX form factor with a length of 160 mm
ORDER NOW
Kolink Modular Power 600W 80 Plus Bronze Modular Power Supply @ £49.99 inc VAT
Modern Design, Semi-modular cable management, 546W and 45.5A on a 12V rail, 80 PLUS bronze certificate for high efficiency
ORDER NOW
Kolink Modular Power 700W 80 Plus Bronze Modular Power Supply @ £54.95 inc VAT
Modern Design, Semi-modular cable management, 648W and 54A on a 12V rail, 80 PLUS bronze certificate for high efficiency
Only £54.95 inc VAT.
ORDER NOW
.The warranty has been increased to 3 years for the entire range, and the wattages range from 400W - 700W wired, and 500W - 700W Modular. Stock will arrive in the next 10-14 days and represents another solid upgrade from Kolink.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
