You can just squeeze a reference RX 5700 XT in
https://www.overclockers.co.uk/powe...ddr6-pci-express-graphics-card-gx-198-pc.html
And at that prices there's probably little point in looking at the non-XT
There is the Red Devil Vega 56 at £300
https://www.overclockers.co.uk/powe...hbm2-pci-express-graphics-card-gx-193-pc.html
i'll leave others to suggest 2nd hand options.
Nah, the 5700 XT's temps are fine with some tweaking. Reviewers don't do undervolting and fan curve tests as part of their review so things always look worse than they are in the real world. There are 5700 XT owners on these forums who will attest to that fact.Thanks. A 5700 XT was on my radar, but I read that they run very hot - My case isn't the biggest (Raijintek Thetis), so is quite a warm environment already. Food for thought though.
I'd also say that a blower style cooler would be better for your Thetis to expel heat straight out of the case rather than a dual fan hobby dumping heat back inside.
But it's still not "loud" or "noisy". There's a difference between fan noise and moving air. A few owners here can describe better but the increase in "noise" is just air movement, it's not actually loud or high pitched.The drawback will be extra noise when you use custom fan curves to expel the heat, though
