Anyone recommend a combined Washing Machine / Tumble dryer? Ta
I have a Hotpoint RD966 and I absolutely love it it has a giant port hole so you can easily see inside your washer and it's super quite the only downside is some of the washers have quite a long cycle I think the daily wash&dry is something like 6+ hours think it holds 10kg load and it has the instructions/ wash cycles on the inside of the soap draw so you don't have to click between each one to see what they are you can just open the draw and go oh I need setting 5
Had my Bosch one for a few years and it’s been solid. Takes about 2-3 hours to do a dry.
Yea thankfully I live alone so I can just put it on over night but families it takes the ****6+ hours! Yikes
