House was built in 1903 and the plaster isn't the best. Trying to hang some curtains in one of the back bedrooms and the pole that was up is somewhat wobbly (no curtains on it atm).
I took the wobbly bracket down, and the took the wall plug out. The plaster is quite crumbly, and when weight is applied to the bracket it levers on the bottom of the round bracket and pulls the (single, central) fixing screw out the wall. I'm quite sure once the curtains are on it, it wouldn't take much to pull it down.
I stuck a screw driver into the hole, and it goes about 60mm and hits something squashy - I wonder if whoever put it up lost a wall plug down there.
The brackets are held on by a single, central screw. One half is a thick pitch screw for gripping the wall plug and the other side is a fine pitch thread for the bracket to attach to.
Unless I replicate this screw, I can't drill in and find brick (maybe that's what the previous person did?).
I did consider something like
https://www.ebay.co.uk/itm/Curtain-...der-Stand-Wall-Mounted-Brackets-/283369829396 but as it has a large central hole already, I'm worried that trying to drill 3 holes to mount that would result in one massive hole where all the plaster used to be.
or do I fill it with filler, smoosh a wall plug in, let it set and hope for the best?
