- 19 Feb 2007
- Northampton
Currently have Corsair Vengeance RGB Pro 3200MHz CL16, Is it feasible to overclock it to 3400MHz or higher ? Also what type of voltage increase am I looking at then ?
Any luck with this Dice?Currently have Corsair Vengeance RGB Pro 3200MHz CL16, Is it feasible to overclock it to 3400MHz or higher ? Also what type of voltage increase am I looking at then ?
While it might not make "much" difference to performance..."don't bother" seems a bit of a narrow view on the matter.
Yep! The latest AMD stuff likes fast memory...Agreed, especially with something like ryzen, where ram speeds and tightening offer nice boosts.
People OC for all sorts of reasons...because they can...fun...benchmarking...bragging down the pub...all good.
Worth doing sometimes..especially if you can tighten timings...2T to 1T etc.
@8 Pack I'm sorry to ask such a noob question, how would I go about getting 3600c14 on an ASUS Prime Z370-P? Currently on XMP, is it just as easy as changing the option to 3600 or is there a lot more to it than that?
Intel don't waste your time c16 to 14 offering almost nothing... 0.01% I bet...
Don't bother to listen t the advice of don't bother.I asked a similar question regarding 8Pack 3200 RAM and pushing it up to 3433, the response was "don't bother" as the extremely minute gain won't be felt anywhere other than a benchmark and even then it's hardly anything.
I'm using 2 kits 8pack 3200 running at 3600, using timmings from the 3600 kit, but same voltage as 3200. All other timmings auto. Haven't tried tighten the timmings just yet, but running stable. A small increase in voltage won't be a problem. 1.4 or 1.45 seems fine. As far as the sticks get some decent airflow, it's fine.
Yeah the response was from 8Pack of all people. you know the guy who would overclock his coffee cup if he could.
