Voxi and Vodafone pac
29 Sep 2003
Newcastle upon Tyne
For the purpose of a PAC, do voxi and Vodafone count as two distinct networks (i.e., can I port my number between the two with a PAC)??
many thanks
m.
Moving from Vodafone to VOXI they can just port you over on the spot without fiddling about with PAC codes. I did it via their web chat.
Moving the other way may or may not be the same but I’ve not tried.
Many other use Vodafone infrastructure but are treated as separate so you should not have a problem porting back and forth between them
I understand that but I’m looking to only temporarily be on voxi once my Vodafone minimum term ends and then go back to Vodafone after seeing what Black Friday deals there are that make it cheaper than voxi.
Yes virtual networks are counted as separate to the network they piggyback on.
VOXI is Vodafone though as it's a product by Vodafone, not a network piggying off Vodafone's network in the standard sense.
They are the same company. When you sign up to VOXI and activate your SIM, you also get a Vodafone account you can sign into but it just has limited features as VOXI is still classed as their "Youth service".
