Hi all,
So I want to run 4 x 120mm Noctua F12-F Chromax fans off of 1 header on my motherboard. Its an ITX board so I have only 2 Fan headers, 1 for CPU and 1 for SYS_FAN. I want the WC Pump to have its own header which leaves 4 fans to run from the CPU_FAN Header.
A colleague at lunch voiced a concern that running all 4 from 1 header might be too much, or rather concerned the thing might melt or similar.
I was looking to join 2 fans from each radiator together with a y 4-pin cable, then connect the 2 y 4-pins together with another one, and have that connected to the fan header.
Thoughts?
Thoughts?
