So I got some Thermal Grizzly Kryonaut today and I was excited to see if that paste would lower my temperatures a bit on my Ryzen 9 3900X. I run it in an ITX case Sharkoon QB one, with a Corsair H100X 240mm AIO with 2x Noctua NF-A12x25 PWM fans, a Gigabyte X570 I Aorus Pro WiFi board and a Zotac RTX 2070 Super Twin Fan.
But holy crap that paste sucked BIG TIME in my build. I tried 4 times to reapply and test, but the temperatures were much worse than with the thermal paste the corsair H100X and pre applied. The first run with AIDA64 CPU/FPU/Cache stress test results in an 'stop hardware failure' error
, something I never got the hundreds of times I ran the test. Second time with reapplying the pc shut off during the test. The 3rd time it ran for 20minutes fine but was hitting 95c on the spikes
. 4th time I reseat it again with less paste, but the temperature rose to 90c immediately upon starting the test, so I stopped it. I then decided to pull it all apart again and drop the Kryonaut entirely. Instead I found my trusty Gelid GC-Extreme OC thermal paste, and I then applied that onto the cpu. And now the spikes fell to 88c and the average temperature would be around 79c in the same AIDA64 CPU/FPU/Cache stress test. And the test runs stable and fine.
I paid $£15 for that crap tube of 5.5gram Kryonaut.
My advice is that for a hot cpu like the Ryzen 9 3900X, then use anything else than Thermal Grizzly Kryonaut.
