Honestly I am very impressed with it. Very good build quality and loads of expand ability (some require additional add ins like the ITX mount in the roof).
With the sound proofing panels in place it really is quiet. I have 6 case fans (3 on the rad) and the two on the gpu and it noticeably quieter both under load and at idle. With them off the airflow increases massively, as expected tbh.
Only downsides I have seen so far are the slots at the bottom of the mb tray don’t line up with my x470 board very well. This means the USB 3.0 header sticks out more than I would like. The other is that it won’t take an eatx board like the Rampage VI. You could probably get it to fit but the little slider flap things would have to be removed.
