Should I be upgrading my GPU
10 May 2011
Reading
As per the title, should I be upgrading my GPU?
the reason I ask, is I have upgraded my CPU to the 9900KS from a 8600k.
I currently have 2x EVGA FTW3 1080ti's in sli (soon to be single card ditching sli). should I be looking to have a better GPU paired with this new CPU?
TNA
TNA
Caporegime
13 Mar 2008
Greater London
Nope. Hold on, not too long left for the 3000 series to come out. Maybe sell one 1080 Ti now though while price is high.
I think it will be out either Q1 or latest Q2 next year.
22 May 2010
Minibotpc
Sorry to jack the thread! I'm in a similar situation, 2 x 980ti's and since sli is dead now... is it worth side stepping to a 1080ti and hold out for a few months until faster cards come out or just stick with the sli config for now?
29 Jun 2016
Up Norf
The 980ti is still a good card, however you're probably at a point where an upgrade to the right card you would see a good improvement.
22 May 2010
Minibotpc
Would you recommend a 1080ti then? Its a good 50% gain at least and upgrade again when RTX cards are actually worth it.
29 Jun 2016
Up Norf
Depends, if you are on 1080p @ 60hz then the 980ti will be absolutely fine until the next badge of cards release next year. if you're at 1440/144hz then the argument for an upgrade makes more sense.
6 Jan 2013
Rollergirl
I would wait if you can handle another 6 months maximum. Not only will it give you a choice of cards just released, if you don't fancy one of those then the 1080ti second hand price will be much less by then.
