I'm rebuilding my PC after many years so considering water cooling.
TL;DR
I'm looking for recommendations for a PWM pump / res combo or componets that can be connected directly with a vertical cylinder res mounted directly above the pump in classic style. D5/DCC most likely with suitable res but I'm confused by all the options and flow rates on OC and elsewhere. Mutiple rads with CPU and GPU planned.
Detail
Planning
Case: Fractal R6
AM4 Ryzen 3000 , likely to be 12 core, but may be 16 if the price is right.
RTX 2080 / Navi may be added to the loop later.
Up to 3 240/280 rads in series with the CPU and GPU block.
Limit on rad sizes on the R6 as I still get a lot of use form my 5.25 bay.
Having looked at quality AIO etc, I figure if I buy a decent pump and res combo then I can add rads and blocks to suit my needs with more flexibility. Initially I plan to use barbs, soft tube and clips, but once I have a setup I'm happy with, most if not all will move to solid tube.
I can't see any recent recommendation on pumps and the D5/ DDC see to vary from 200Lt /hr to 1500 Lt/hr so a big difference by brand. That and the res combinations has me confused as there are a lot of combo's, many with minimal volume in the res. I'd prefer a bigger res > 200ml as I have space and the side panel will not be windowed as the case lives under the desk.
The best value pump res combo is ?????
Thanks in advance.
TL;DR
Detail
Planning
Case: Fractal R6
Thanks in advance.
