OcUK Staff
- 26 Nov 2014
- Stoke
Available to configure today, we have the brand new Lazer3D LZ7 XTD. Available as a stand alone configurator, or an upgrade kit for existing LZ7 owners, the LZ7 XTD builds on the excellent reputation of the LZ7 by increasing the size by a mere 3.33 litres (from 7.09L to 10.4L), but in doing so, allows for much more hardware support, including 280mm dual slot VGA cards, 120mm or compact 140mm AIO's, 135mm CPU coolers and more. Added to that is the option to now mount your LZ7 XTD case both horizontally or vertically using the new LZ7 case stands, which are available in several colours. Also new to the XTD are the new fusion panels, mixing both frosted and clear sections onto the same panel for some impressive looking results! Of course with a bigger chassis, the airflow has been further improved, and there's a variety of panel options to suit your particular requirements. The case remains ITX, with SFX PSU support, and there's space for 2 x 140mm fans and up to a rear 92mm fan too. All the original corner column options are available from the original LZ7 too, so if you're that guy who wants red and orange corner columns with grey top panels, white side panels and a blue vandal switch, go for it (and also get an eye test
For those who already own the LZ7, the upgrade kit represents a cost effective way of upgrading your LZ7 to take advantage of the increased compatibility. Both the case configurator and the upgrade kit is fully in stock and ready for orders today, the case stands are also available separately too, and are fully compatible with the original LZ7 chassis. Finally, if you have any other questions, I'm sure @K888D will be happy to help
Frankly I'm impressed once again by the quality of the LZ7 XTD and the thought that has gone into it. Truly one of the most impressive SFF cases on the market, and ultra customisable to boot!
Lazer3D LZ7 XTD Mini-ITX Case Configurator @ £189.95 inc VAT
Long anticipated upgrade to the LZ7, Allows 280mm dual slot VGA cards and 120mm AIO's, Highly customisable configurator, Improved cooling capacity, Just 10.4L in volume, Premium finish and aesthetics
Only £189.95 inc VAT.
ORDER NOW
Lazer3D LZ7 XTD Upgrade Kit @ £79.99 inc VAT
Upgrade Kit for the LZ7 Case, Converts LZ7 to LZ7 XTD, Choice of panel colours and finishes,
Only £79.99 inc VAT.
ORDER NOW
Lazer3D LZ7 Case Stand - Midnight Black @ £21.95 inc VAT
Visually impressive stand for LZ7 XTD series, Allows vertical or horizontal orientation, Midnight Black matte finish, Made of high quality 5mm acrylic
Only £21.95 inc VAT.
ORDER NOW
Lazer3D LZ7 Case Stand - Moonlight White @ £21.95 inc VAT
Visually impressive stand for LZ7 XTD series, Allows vertical or horizontal orientation, Moonlight White matte finish, Made of high quality 5mm acrylic
ORDER NOW
Lazer3D LZ7 Case Stand - Mineral Grey @ £21.95 inc VAT
Visually impressive stand for LZ7 XTD series, Allows vertical or horizontal orientation, Mineral Grey matte finish, Made of high quality 5mm acrylic
ORDER NOW
Lazer3D LZ7 Case Stand - Midnight Black/Walnut @ £29.99 inc VAT
Visually impressive stand for LZ7 XTD series, Allows vertical or horizontal orientation, Midnight Black matte & Solid Walnut wood finish, Made of high quality 5mm acrylic & 5mm solid walnut wood
Only £29.99 inc VAT.
ORDER NOW
)For those who already own the LZ7, the upgrade kit represents a cost effective way of upgrading your LZ7 to take advantage of the increased compatibility. Both the case configurator and the upgrade kit is fully in stock and ready for orders today, the case stands are also available separately too, and are fully compatible with the original LZ7 chassis. Finally, if you have any other questions, I'm sure @K888D will be happy to help
Frankly I'm impressed once again by the quality of the LZ7 XTD and the thought that has gone into it. Truly one of the most impressive SFF cases on the market, and ultra customisable to boot!Lazer3D LZ7 XTD Mini-ITX Case Configurator @ £189.95 inc VAT
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
