Hehe. I go it mine new for 159 quid so it made sense for me. I don’t have access to the board marketplace yet
not happy with the crucial m.2. It running 48 - 50 degrees when the wd nvme is at 34 so I’m getting constant high temp alarms. Loads of space in the case. May return it and buy a wd m.2 (non nvme) as it seems hot to me.
for my setup, I’m gonna put docker, app data and vms on the nvme.
The 250gb ssd will be there as a temp download directory before stuff gets moved off to the array, so when stuff is unraring it doesn’t kill the nvme disk.
The 500gb crucial I was going to put my audio mp3s onto. They are on my Mac at the moment, and cause I have a whole house sonos system, I need to leave the Mac on. I didn’t want them on the array as the Mac is a bit particular with mounted disks spinning up and itunes that manages them goes pear shaped, so an m.2 which is instantly accessible as the iTunes share for my Mac will get the media off the Mac
that’s the plan anyway. I’m sure it will all change.
I only came here to look for a N40L BIOS update but found myself reading through the whole thread. Is there an update to your finalised build and what your current setup is?
