- 29 Sep 2010
if you’ve seen my other thread, I need to wc a GPU but it needs to be low profile and most blocks won’t quite fit in my case, I’ve found a raijintek universal vga block on OCUK, now, it’s an old block, states compatibility of the Nvidia 6xx/7xx cards, so old stuff.
But the block should be okay for cooling the gpu itself, but I don’t know if this would fit a more modern gpu? Obviously compatibility lists are out of date so just want to know if the mounting distance differs much between cards now?
This is the block https://www.overclockers.co.uk/raijintek-gwb-c1-vga-water-block-universal-wc-008-rt.html
Thanks in advance
Thanks in advance
