- 20 Apr 2004
- Somerset
I'm facing a quote of 1k for a quattro TT.
Shock as forum geezer continues to spend his time belittling others’ posts.
I cheated a bit. Toyota did it while the engine was out for a recall. They only charged for the part![]()
While I don't have much experience of having clutches changed, that's 6 times the torque of my old 911 turboSome interesting figures here, an OEM clutch for a 16 Litre 620 BHP Scania V8 HGV - which produces 3000Nm of torques - is ballpark £1k and about that again fitted at a dealer, going elsewhere you can easily halve that, yet you can guarantee it'll be the toughest of any of the examples listed in this thread which is food for thought perhaps....
, is the clutch itself massive or just made of a a very hard wearing material.The 911 - and practically any other car to be fair - is undoubtedly quicker but it can’t pull upto 150 tonnes (moving heavy plant etc under STGO regulations) which is the sort of use a 620 V8 would be used for, the headline BHP figures are relatively low given the engine size (16 litre in this case) but it’s all about the torque.While I don't have much experience of having clutches changed, that's 6 times the torque of my old 911 turbo, is the clutch itself massive or just made of a a very hard wearing material.
Wait, your ultra-reliable Toyota had to have a recall requiring the engine to be taken out?![]()
My father inlaw used to be a trucker, retired last year. From what hes said quite a few are now auto, which i guess solves the burnt out clutch problem. Although its still a massive amount to pull.The 911 - and practically any other car to be fair - is undoubtedly quicker but it can’t pull upto 150 tonnes (moving heavy plant etc under STGO regulations) which is the sort of use a 620 V8 would be used for, the headline BHP figures are relatively low given the engine size (16 litre in this case) but it’s all about the torque.
A bit of both, yes they are relatively large and indeed made of strong stuff that said they are easily killed by ham fisted drivers, we had an agency driver at Stobarts destroy a clutch in a Volvo FH by it turned out holding it on “the bite” in hilly stop-start traffic, the truck itself had only been delivered to our depot the previous week and had less than 1k Km under its wheels!
Yes, the cab tilts to expose the engine, it is however still a big job to get at the friction plate.Doesn't the cab lift on those though?![]()
Unfortunately not, automatic trucks are effectively an automated manual transmission rather than say a torque converter, gear changes are still via clutch etc but operated by computer rather than driver (you can though over ride it)My father inlaw used to be a trucker, retired last year. From what hes said quite a few are now auto, which i guess solves the burnt out clutch problem. Although its still a massive amount to pull.
Had a new clutch and dual mass flywheel today following what I will describe as a ‘burn up’ towing (pushing) a 1475Kg caravan in reverse uphill along a wet/muddy track. £2900 from Kia so done at an independent for £1250!! I thought this was a £4-500 job. Car has 63K miles on the clock. How much have you spent on a clutch!?
You have a Kia Sportage also?Same as mine, it needs doing and would be £1200 also.
