- 26 Jan 2018
- South
Hi all,
I've not long moved into in my first house and I'm still discovering all its issues...
Latest is the boiler, I've noticed over the last few days that the pressure is 0 when it's not being used but when the heating comes on gradually it rises up to 1.3bar and stays there.
The sticker on the boiler says the system pressure should be between 1bar and 1.5bar but from what I've read online it should be at this pressure all the time, even when it's off?
Hot water works fine on demand when pressure is 0 and the pressure gradually rises when the heating comes on to 1.3bar.
I know nothing about boilers so this is all new to me. The boiler is a Heat Line Monza 28 combi.
Is this a problem?
Side note: large radiator in living room doesn't get hot, I've bled it and it only gets warm at the top, bottom still cold so I assume its sludged up, don't know if this is relevant to this boiler issue? It's a 4 bed house and all other radiators work fine.
Is this a problem?
