Hi,
I recently built a pc with an intel i9 9900k, cooled with a Corsair H80i.
I use it mainly for 3D animation and video editing. Normally the temperature of the cores when both video editing software (DaVinci Resolve) and 3D software (Autodesk Maya) are open and in use is fairly ambient, in the 30-40 degree range.
This has been pretty constant for the month I've had the machine in use.
However last night I had to reencode a high bitrate 2 hour video with handbrake software. I noticed the fans going into overdrive so checked the temps and on all eight corse they were in the 80-90 degree range.
I immediately ceased the task and everything returned to normal pretty quickly. All the fans are operating fine as far as I can see.
I know video encoding is a very intensive cpu process, is it possible that it was just a very demanding job, or is it likely I've bodged the h80i cooler install?
Any advice would be much appreciated.
I'm a bit afraid now to do some hardcore stress test in case I fry something.
