- 1 Dec 2015
Prob been mentioned or seen but for those that haven't
https://www.reddit.com/r/Amd/comments/dtjztk/official_aorus_rx_5700_xt_coming_soon/
as lot of comments mentioned its a love child of Gaming OC and Nvidia Aorus cards .
Did some digging with Nvidia Gaming OC and Aorus cards sizing and AMD Gaming OC
Gaming OC
Aorus RTX
RX 5700XT Gaming OC
So it matches Aorus RTX in length beating the other two Gaming OC models, as well as being Thicker and just shy of the Aorus RTX, its also wider then other Gaming OC models that use 92mm fans but slimmer then Aorus RTX that uses 100mm fans.
Looks like 100mm fans havent been used but 92mm with wider PCB and heatsink . Believe Current Gaming 5700 xt is 7 phase design and new RX Aorus should be 10 phases , dont think it will be 12 like NVIDIA Version due to slimmer PCB and lack of space
Just to summarize instead of having to hunt through the thread for official info (since we ended up basically giving away the farm in this thread):
~2.5 Slots, L= 290mm, W= 123mm, H=58mm.
Metal backplate seen here. Yes, that is a BIOS switch you see
MSRP: TBD
Release: Soon! They are already in production.
Clocks: Faster than Gaming OC
And before we sign off for the day one last tidbit: 3x HDMI and 3xDP
Gaming OC
L=286.5 W=114.5 H=50.2 mm
Aorus RTX
L=290 W=134.31 H=59.9 mm
RX 5700XT Gaming OC
L=279.85 W=114.35 H=49.55 mm
