** BE QUICK: 16G 8 PACK 3600MHz, SAMSUNG B-DIE, UNDER £100 OH YES!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Though I will try and repeat this come Black Friday, we cannot guarantee it as margin is very slim but we booked this stock at 1.30 rate, the rate is now 1.28 for replenish which may mean keeping it under £100 for next batch could be hard but we always try, but as of today ONLY you can grab one of these awesome kits at sub £100 :
Team Group 8Pack Edition 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit - Black/ @ £99.95 inc VAT https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-08q-tg.html
TDPGD416G3600HC16ADC01, 3600MHz RAM Speed, CAS 16-16-16-36 Timings, 1.20-1.40v VDIMM, Samsung B-Die, Ideal for 3rd gen Ryzen, Ryzen 3000 8 Pack Approved, Lifetime Warranty with OcUK.
Only £99.95 inc VAT.
ORDER NOW
Perfect for Intel and AMD builds being Samsung B-Die makes this RAM pretty much compatible with every mainboard on the planet, even better this is screened B-Die so it will overclock extremely well in both Intel and AMD platforms. :)
Nice, any movement on the 3200 stuff too?
Tempted to upgrade to 32gb ram.
As crazy as it sounds, the 3200MHz cost us more because its stock booked at a weaker pound, so there is nothing we can do I am afraid.
The 3200/3600 is the same bin, same batch of screened samsung b-die, only the 3866MHz is from a higher bin, but saying that 8 Pack has overclocked the 3200/3600 kits beyond 4000MHz before, but of course its no guarantee.
I've been waiting to buy all my stuff in Black Friday but this is too good of a deal to miss out on.
Ordered
Well I seriously can't get it any cheaper unless we sell all this stock so fast, then the GBP goes above 1.30 and I re-buy with the better rate, TeamGroup have put everything into the price I pay, as screened Samsung B-die still carries a premium because it is simply the best IC on the market. :)
I already have 16Gb of the 8Pack 3200MHz RAM. If i add this to it will it all play nicely together, at 3200MHz, or will the difference in rated speed cause problems?
Same binned RAM, just set speeds and CAS timings manually, shall be fine. :)
Will this fit under large air coolers like bequiet dark rock pro 4 or noctua d15?
You can take the tops of the heat spreader off to reduce the height a little. I have it fitted under a TC14PE cooler which doesn't have huge amount of clearance
If I hadn't already filled up all 4 slots with this stuff already i'd be buying more!
on the Asus X570 Strix E-Gaming with a 3700x which is better. is it better to put in 2 x 16gb (3200mhz) cas16 amd optomized corsair lpx vengeance or would 4 of these 8gb (3600mhz) ? purely for gaming
