Kernal Power issue restarting or shutting down hanging
19 Jan 2019
Co. Down, N.Ireland
Hi Guys,
Having an issue all of sudden when I turn computer on mouse will be slow and laggy then will work as normal but shutting down or restarting the system will hang instead of going off which will give me a BSOD saying kernal Power problem Id 41.
Any suggestions about to pull the hair out of my head.
Thanks
15 Oct 2019
Uk
Hi Guys,
Thanks
Could try checking event viewer to see if there's any errors being generated, would run memtest also just to rule out the ram.
Are you running an overclock? If yes would switch back to stock and see if your still having issues.
