- 19 Sep 2019
Hi , What's up with the Ryzen power plans ?
This is how I would expect the power plans to work !!!!
High Performance , Full on, set every thing to 11.
Balanced , Low clocked , but fast to ramp up and slow to ramp down.
Power Saving , Set the clocks to as low as possible disable the others cores, power saving to 11.
But all of the power plan set the clock to the max , push up the voltage (1.35v )and push up the temperature.
So the Ryzen power saving mode sound like a car on the starting line with the fan speeding up and slowing down , going from 40 to 80c every few seconds on the desktop 2% cpu.
So I`m using the normal windows power saver mode which is a constant 35 -36c . 2.1ghz
Why is the standard power plan better than the power made for AMD cpus
Gigabyte X570 aorus master Bios Fc , Ryzen 3900x , Latest windows and drivers , Default all auto , BUT Bclk 100mhz , SVM enabled , Sata Hot plug Disabled , XMP enabled , PCI-e set to gen 3.
