- 7 Nov 2006
Hey folks, wondering if anyone has had similar issues as myself. Got myself a x770 hero viii and 3900x from OCUK end of late week. put all together and realized my AIO cooler bracket was missing for AM4 (previously had 1151 socket, so while I waited for that to come I ran the stock cooler and was getting decent thermals, not brill but not bad. Under full load it would have peaked around 87 degrees or there abouts. Anyhow, my am4 bracket came today, cleaned all up, put the aio cooler back in, mounted as per usual and applied thermal compound and all booted however I notice under load it peaks 95 degrees then thermal throttles, so took all off to make sure paste was sufficient and it was covering the full cpu evenly with no shallow or raised spots, cleaned up again and used different paste this time, tested again and 95 degrees then thermal throttle again, anyone tell me whats going on? I checked and the pump and fans are ramping up when under load too in the AIO cooler.
AIO cooler: H100i v2
Initial Thermal paste: Artic MX-4 (I know its not the best but its all I had here)
2nd Thermal paste, haven't a clue, label is off it)
