Running previous OS installation on external HDD using Virtualbox
4 Jun 2009
South Wales
Hi guys,
I have taken my old hard drive out of my previous laptop and I was wondering if I could use virtualbox or similar to boot/run the original OS off the old hard drive through my current OS on new laptop. Both OSs are windows 10 64-bit. After a quick search online I couldn't find a definitive answer - so it may just be easier to back everything up and do a fresh install if I needed to use a virtual machine, just curious :)
Cheers!
Yeh you can but I am not sure why you would want too.
It's mainly due to software/data conflicts when opening the same type of raw data file from two analysis machines I use for research. It gets quite frustrating sometimes :D
I could also potentially use the hard drive if I were to make a home server or something in the future.
Yes you can use something like Disk2VHD or a similar tool.
Cool nice! Will have a look into it!
However, it may be easier just to copy the data and create a new virtual machine installation.
Cheers guys! :)
If you have Windows 10 Pro, you can use Hyper-V which I find much better than Virtualbox or if you want you could use VMWare Workstation Player which is also free. I tend to prefer the VMWare tools as they have tons of features that I haven't played around with properly yet (like setting up virtual networks between virtual machines).
