PATRIOT VIPER STEEL SERIES DDR4 MEMORY NOW AVAILABLE INCLUDING SAMSUNG B-DIE VARIANTS!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Viper Steel is now available from OcUK:
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-35200C19 4400MHz Dual Channel Kit (PVS416G440C9K) @ £109.99 inc VAT
PVS416G440C9K, 4400MHz RAM Speed, CAS 19-19-19-39 Timings, 1.45v VDIMM, Lifetime Warranty with OcUK.
Only £109.99 inc VAT.
ORDER NOW
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-32000C19 4000MHz Dual Channel Kit (PVS416G400C9K) @ £89.99 inc VAT
PVS416G400C9K, 4000MHz RAM Speed, CAS 19-19-19-39 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
Only £89.99 inc VAT.
ORDER NOW
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit (PVS416G360C7K) @ £68.99 inc VAT
PVS416G360C7K, 3600MHz RAM Speed, CAS 17-19-19-39 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
Only £68.99 inc VAT.
ORDER NOW
Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (PVS416G320C6K) @ £59.99 inc VAT
PVS416G320C6K, 3200MHz RAM Speed, CAS 16-18-18-36 Timings, 1.35v VDIMM, Lifetime Warranty with OcUK.
Only £59.99 inc VAT.
ORDER NOW
The 4400Mhz and 4000MHz kits use Samsung B-Die IC, but its not screened B-die but they still generally do as labelled on the tin in a good mainboard and with a CPU with good controller.
The slower kits are not B-die.
Wow!!! They are some amazing prices! Tempted to get 32gb of 3600
Are these in any comparison to the team group Vulcan, or Corsair vengeance?
3200 and 3600 shall be very similar to regular teamgroup vulcan and corsair vengeance stuff, all will perform similar, buy cheapest or best looking. :)
Nice!
How will the 3600 compare with the 3200 on a B450 board with a 2700x or 3600/3600x (Looking at the MSI Tomahawk Max and the 3600 isn't on the compatibility list, so that may be a non-starter :()
Nice!
Last gen Ryzen could be picky with memory, 3000MHz should be fine and good chance on 3200MHz just not guaranteed.
Gibbo how would 2 x 2 kits of the 4000Mhz work to make a 32gb system? Cant find a mobo with a qvl listing 32gb of this setup and was worried.
Would they still be able to hit 3733 or so to try to squeeze everything the cpu can offer? Not sure how the IF on my processor would reach 1900 to get 3800mhz but would love to :D
Well you can normally happy combine dual kits to make quad kits, so it should work fine, but as always the limitation shall be the CPU and mainboard, especially when populating all four banks.
