- 1 Jul 2015
But should i choose the ryzen 7 2700x enigma enthusiast or the i7 9700kf firefly enthusiast build at 290 more? Is it worth the extra.?
I'd be getting a build based around a Ryzen 3600x or 3700x if I were you.
My basket at overclockers uk:
- 1 x MSI B450 TOMAHAWK MAX (Socket AM4) DDR4 ATX Motherboard= £106.99
- 1 x AMD Ryzen 7 3700X Eight Core 4.4GHz (Socket AM4) Processor - Retail= £289.99
- 1 x Patriot Viper Steel 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (PVS416G320C6K)= £59.99
- 1 x Palit GeForce RTX 2070 SUPER Game Rock 8192MB GDDR6 PCI-Express Graphics Card= £449.99
- 1 x Super Flower Leadex III 550W 80 PLUS Gold Modular Power Supply - Black= £59.99
- 1 x Gigabyte 1TB M.2 PCIe x4 NVMe SSD/Solid State Drive= £95.99
- 1 x Kolink Castle Midi Tower Case - Black= £42.95
Similar, but not quite the same. Bigger faster SSD 1TB but no additional hard drive, better motherboard, better RAM, better PSU, same case.
Cost would be more than £1199 with the build I think though, you'd have to get them to quote it for you.
Got recommended this
What is an x570 again?
B450 is the low to mid range chipset for the last gen of Ryzens (2700 etc). It is compatible with the current gen (3700 etc) with a BIOS update. People tend to recommend the MSI B450 Tomahawk Max which doesn't need a BIOS Update.What is an x570 again?
I would get the Leadex/EVGA 650W psu so you have more room to add a high end GPU in the future.Got recommended this
Cracking build that huge performance for the money as that’s capable of 4k but will be properly quick at 1440P and 1080P.
Id only consider spending a bit extra on an X570 and gen4 SSD but in fairness you’d be hard struck to notice the performance difference between an SSD that reads at 5000mb/S compared to a 3000mb/s one.
